Help me, OEM Infotainment and what I need to run full custom system
  • 4
mccar
CarAudio.com Newbie
So, I'm trying to figure out what I need to hook up and control my system from my stock unit. I won't be using it for any power to speakers, just controls (volume, left/right, fade, set eq to flat for dsp). Also, I can't change it anyway b/c everything in the car runs through it (including A/C, suspension, etc).
JL FiX or Loc?
Audioson bit?
There isn't (or I cannot find) some articles explaining what is needed. These say the flatten OEM corrections etc, but I don't get it. Is there a useful article or explanation somewhere I can read?
Additional, I think I'd like a dedicated DSP and then to go amps rather than an AMP/DSP combo. Prefer the flexibility of the first with dumb amps.
Thanks in advance.
Some aftermarket HU can support all the factory controls just have to see if any options available for your model.
There is no way an aftermarket headunit will be able to control everything in my car unfortunately. This unit does suspension changes, A/C and heat, various screen adjustments and displays, lighting, basically all of it
Yeah, I saw that (JL FiX). So, do I have to use one of these? Are there other options out there?
That’s a good question on the JL Fix. It basically cleans up the signal for your amps. I literally have a question to JL right now about it since I plan on running their VX line with DSP I’m wondering if there’s any benefit to it. I’ll let you know what they say. I’d be more inclined to use one if I was not running DSP for sure. It’s not that much more than an LOC and it has added value.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
173
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
192
11
430
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
270
mccar
CarAudio.com Newbie
mccar
1 star state
Bass Addict
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
