Checkup on my design
  • 2
ChevelleMan73
Muscle-Car Man
Hey guys it's me again. I was wondering if you guys would beable to check this design out, see if it's solid. I was worried about getting too much port noise, do you think ill have a problem with it? The vent is 2"x13.5"x26.5" The box if my calculations are correct is 3.06cf tuned to 27.6 hz. Let me know if this box will work with two Kicker Cvr10's I want to start cutting soon so a quick response would be greatly appreciated.
Stupid attachment manager makes all my pics look like s**t so here are the dimensions.
Top and Bottom - 30x17.75"
left side - 17.75"x13.5
baffle - 27.25"x13.5
right side - 17"x13.5
Back - 28.5"x13.5
Port 1 - 14.25"x13.5
Port 2 - 8.5"x13.5
Thanks for your help guys.
Joel
yes you should add at least one piece from the middle of the front baffle to the back of the box.a bit yes. you just need to find out how much volume your braces will displace and accout for it by making the box slightly larger
693
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
859
ChevelleMan73
Muscle-Car Man
ChevelleMan73
Grants Pass, OR
hofulstrof
