Chevy Cavalier AUX Input
  • 3
zwhite93
I would like to add an auxiliary input to my 2004 Chevy Cavalier factory radio. It is an AM/FM/CD (single) unit. I know that there are converter boxes out there but here is what I would like to do. Can I make a Y cable out of all of my speaker leads, tie together the +'s and -'s into two leads, and run them to a 3.5mm plug? I am assuming I will need a small amp so that the battery isn't drained on the source (an mp3 player), and will need inline switches to reduce noise when I am not using the AUX input. Can I put one inline switch on the high side of each of the four + leads? I am aware that by tying all of the +'s and -'s together, I will loose all fade and balance, but I keep everything zeroed anyway, so that is no biggie. What would you recommended for a 12V amp? What other issues might I run into? Thoughts? Thanks
PAC audio makes one under the name Peripheral iSimple Gateway or something like that, they are stupid simple to install
Thanks, but the factory radio is a POS- otherwise I would add a conversion harness/box. The install doesn't scare me, I just would like some input before I go slicing and dicing. Thank you.
get a fm signal thingy. I used to have one for my S-10. I just plugged my ipod into it and picked up the music and channel fm88.8 What ever it is you think you going to do, wont work.
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
765
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
zwhite93
zwhite93
Phoenix
subzero
