los33
Car Audio G
Yes its a cz702..Hi..super... your HU .. was that a cz702..?
anychance that you can find me the color codes and maybe pin numbers for your connector as they are a bit different to mine ?
for one, the pink lead, third from left on your connector, is red on my connector...and second from right is free on yours, on mine there is a yellow lead...and the third from right on yours is red...on mine its orange with white stripe....
So if you coul help on this too it would be super
Yours and mine should be exactly the same.
Whatever you removed that connector from has different pin patterns.
Check on the unit that connector came from and see if the pins match or are different.
