clipping issues with alpine pdx-f4 need suggestions!
  • 2
baseball9734
boston
i am powering 2 alpine spr-60c 6-1/2 2 way speakers with 1 inch tweeters with crossovers, and 2 alpine spr-69 6x9 coaxial 2 way, with the alpine pdx-f4 amp. the gains are only up to about a quarter of the way turned up, and the speakers are decently loud, but not as loud as they should be, if i put the gain up any more i start to hear the clipping. when the lpf switch is on no sound comes out of the speakers, very faint from back, sounds decent with the hpf on when switched to off it sounds horrible. any suggestions or fixes anyone can think of?
With the frequency response of those speakers you shoud be using the HPF, they don't have good low frequency response. Try setting the HPF in the 45-55hz range, from there you can increase the frequecy if you are still getting distortion. You should be able to get clean sound from them but if you want more bass you will need to replace those speakers or add a subwoofer.
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
11
717
Don't recall off hand. Both single dins. One excelon, one not.
932
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
baseball9734
baseball9734
boston
vaiboy
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
