Coil Pairs, LMS & MASS Underhung
ciaonzo
TheContinental
11,703
76
WI
6 pack of sweet coils. Selling only as pairs, no singles.
A) Pair of original MASS underhung dual 4 ohm coils - ID 3.03" / OD 3.3" / WW .8" / FH 3.25"
8 layer aluminum coil with Kapton former
B) Pair of tall single 4 ohm coils - ID 3.03" / OD 3.2" / WW 2.9" / FH 3.9"
4 layer aluminum coil with a split aluminum former
C) Pair of MONSTER LMS single 4 ohm coils - ID 3.03" / OD 3.44" / WW 3.5" / FH 5.5"
Variable layer aluminum coil with a split aluminum former
Will take tons of power but you will need a huge motor, lol. Use a top plate height of 12-19mm
A) $100 shipped
B) $100 shipped
C) $150 shipped
CONUS only, please.
Bet those 3" LMS coils would work nice in '02 "big gap" sig. Wish I still had a couple.
I'll bet they would. And man would they soak up the power, these things are huge. Probably wouldn't be worth much above 60Hz but they would absolutely crush everything below that, provided the soft parts can support the physical throw.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
617
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
