Command Start issue - Help!!
  • 1
Aaron407
Canada
Hi everybody,
I bought a 95 grand prix a few months ago and only recently started trying out the remote start. It had been previously installed so I have no idea what all went into it other than the fact that it's Command Start brand. I also have no idea if it ever worked in the first place. The key for the ignition has a resistor pellet in it, and I've heard that it would then require a bypass to work, but I'm not sure if one had been installed or how to find out. Anyway, when I try to start the car from the remote, all that I get is a continuous clicking from the second starter relay until I stop pressing the button. Does anyone know what the problem might be? Could this be related to the possibility of not having the bypass? I know this doesn't give a lot of information, but any help would be greatly appreciated.
407
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
983
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
Aaron407
Aaron407
Canada
Aaron407
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
