StanJarensky
Alright, hey guys, I have a 2013 Ford Focus ST. The car comes stock with eight speakers in the doors (a tweeter and woofer each), a center speaker, an amp and a subwoofer in the hatch. The system as a whole isn't bad but I'm looking for something better. A lot of people said that replacing the door speakers is a pretty massive upgrade so I went ahead and bought two sets of Infinity Kappa 60.11CS speakers and replaced all eight door speakers. They were right and it is a pretty big upgrade but now I'm looking for more bass and that's where the problems really start.
The stock amp isn't that great...the stock speakers were horrible 25w speakers so the amp really doesn't push too much power out. The problem is that if you replace the stock amp, you lose function in MyFordTouch, navigation, etc. so a line-out converter needs to be purchased and an additional amp needs to be added.
I'm looking at the LC2I for the line converter and a 5-Channel amp such as the Rockford Fosgate R600X5. The problem that I'm having is I'm not sure how everything is supposed to be wired. I've been told that I need to set the front door woofers as the input for the LC2I and then have the outputs go to the second amp. What confuses me is the LC2I only has two sets of outputs--a "main output" and a "bass output". Obviously the bass output is going to go to the sub input on the second amp but all 5-channel amps have inputs for front AND rear connections. Does the main output for the LC2I go to the front inputs on the second amp and do I leave the rear inputs disconnected?
I've attached two pictures of the LC2I and Rockford amp so you can hopefully realize what I'm trying to say. Thanks guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
