Confused on RMS rating
  • 2
AL210
PA
I'm confused about these ratings for sub woofers. I currently have an Alpine SWS-10D2. It has two 2 ohm voice coils. The specs say its rating is max 500RMS with 1500 peak.
Does this mean for each coil? If I wire the coils in parallel would the rating be max 1000rms be cause the power is split between the two coils? If the coils are in series then the rating would be only 500rms since the power flows thru each coil?
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dayuuum!! LOL. Going CHEAP sometimes doesnt pay..LOL 💩 💩
13
Hey guys I'm new here I'd like first and foremost that I'm not greenhorn but I haven't been an installer for 10+ years either. So the issue I am...
AL210
AL210
PA
macsdad
Dylan27
    Jun 4, 2024
winkychevelle
    Jun 3, 2024
