TomServo
Hey, everybody! I've just come into a 1997 Celica GT that I'm trying to fix up for my daughter. It's running perfectly fine, but someone previously tore out the radio (and cut the convertible top, jerks), so I'm trying to put in an aftermarket radio and running into some roadblocks:
1. The radio has a weird problem. I found a matching wire harness on Amazon after some searching, but the radio doesn't seem to turn on at all. So, I broke out the multimeter and tested the bare yellow - 12v with the switch off. Bare red - 12v with the switch on. Bare ground seems to be good. So, the radio should work, right? Well, if I wire the yellow directly to constant power (yellow) on the stereo, then contact it with the multimeter lead, it no longer reads 12v. To restate - Bare yellow = 12v. Wire yellow to yellow = no longer 12v. I don't know why. My limited electrical experience does not lead me to any obvious explanation.
So... is there any fuse-related solution, or obvious solution? Could it be ground related? I have tried three separate radios and have the same problem with all three. I have tried grounding to the metal bracket or the black ground wire.
2. Also, just over the stick shift there's the electric convertible top switch and the rear window switches. The electric convertible switch works fine - the top sets and retracts without incident - but neither of the rear windows raises or lowers. So, I'm convinced that those switches are on their own fuse. Can anybody confirm or deny this? Or know exactly which fuse it is? Any complete fuse layout is appreciated, I've Googled and found some but it's not helping to this point.
Thanks in advance for any help to these questions. I'm looking forward to your responses.
