Copying and burning of DVD
Some time ago, a friend bought a DVD burner, and he wanted to copy a few classic DVD-video discs. However, the problem that DVD can not be copied successfully comes out when copying DVD with nero 7.0, so he asked for help.
In fact, it is known that not all the DVD can be copied simply. For the general DVD data discs, it is very easy to backup the information of DVD with Nero 7.0. Just following the step by step instruction, the copying task will be done. If you are still not very clear, please get more detailed information at http://www.nero.com/enu/support-nero7-tutorials.html
But some DVD are encrypted and protected by means of CSS. At the moment, you have to do something for crack. Choosing free software or not is up to you, such as DVDFab HD, DVDShrink, and DVD43.
The passage is prepared for the beginners. Now, Take Pavtube DVD Copy as an example. There is not so much software that supports both copying and removing CSS while Pavtube DVD Copy is good choice, which can be valid for 5 times within the first month if you use trial version.
Operating Pavtube DVD Copy is very simple and easy. See the screenshot below.
If you just want to rip some chapter, just tick it and then it will be done. Want to copy the full disc? You can choose “Full Disc” mode to complete the copying task.
Here is the guide for how to copy DVD to a blank DVD.
First make sure that you have installed DVD+/-RW.
There are two steps during the copy process: first it will copy the DVD movie to a temporary folder on your computer, second copy the files in temporary folder to the blank DVD disc.
When the first copying process is done, eject the original DVD disc and insert a blank DVD disc, click "ok" on the pop up diallog box. Then it will start to burn the DVD movie to the blank DVD disc. Now you can enjoy your copied disc!
Get more information here: http://www.pavtube.com/dvd_copy/guide/
Note: Please make sure that there is enough space (at least 5G on the hard disk) to store the folder used for the conversion process.
