Correct gauge for wiring Subwoofer from Amp
  • 2
ArnoldShortKnickers
CarAudio.com Newbie
I installed a subwoofer + amplifier in my car, but I am unsure if I have the correct gauge wire connected between the amplifier and the subwoofer.
The amplifier outputs 250W RMS (at 2 ohms). It's connected using 8 AWG wire for power and ground.
The subwoofers are two 12" subwoofers pre-wired and pre-installed in an enclosure rated to handle 200-400W at 2 Ohms.
I used 8 AWG wire to connect the amplifier to the subwoofer. Also I didn't have speaker wire that thick so I used the super stiff home wiring cables that were 8 AWG in thickness.
Given the configuration described above, is 8 AWG wire too thick for the amplifier to subwoofer connection? The wiring kit didn't have any 8 AWG cable for subwoofer so I have a feeling that I should've used the thinner wires that it came with but I'm wondering how that would work if the amp is consuming 250W (more like 500W since it's not a class-D amp) and providing that power to the subwoofer, so based on that I figured I should use the same AWG as I did for power/ground.
What gauge speaker wire should I use?
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
710
Nope, just purchased and received it for my brothers "74" Ford Currier truck resto build. Small 4 cahnnel taramps and a set of nice 6.5" Pioneer Z...
12
ArnoldShortKnickers
CarAudio.com Newbie
ArnoldShortKnickers
Slo_Ride
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
