Corvette Setup
  • 5
MikeHoncho
I've got a Rockford t500bd1 with a born wattage of 625. I had a rock T1 but I don't think I had enough air space. The air space I had was about 1.3. The T1 was not hitting that hard. Any suggestion for a replacement for the T1 that requires less air that Bangs hard! A bigger box is out of the question. Thanks.
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
756
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
587
MikeHoncho
MikeHoncho
Fresno, CA
MikeHoncho
Dylan27
    May 19, 2024
Dylan27
    May 18, 2024
