couple of questions: Ground loop and Wiring
caps>garbage can. if you need more power that bad, get an extra battery, and do big three if you haven't yet.
since everyone is hating on the cap, i will remove that from my system.
round speakers sound the best....if your not in love with the 6x whatever's id ditch em and get some 6.5's
i wish i kinda figured this out earlier, since i have 4 6x8 and 2 6x9. but screw it, ill keep mine, they are installed already...
i should of been working on the ground loop but i was locked on the fading situation.
so i doubled check with my friend that did the wiring, and he told me that on day 1 and 2, the fader was working right. at this point in the game, i think something in the mtx reQ5 is messed up. i say it is the mtx req5 and not the amp is because when i pulled the rear rca outs, the rear speakers were still working. if the mtx req5 was working 100% correct, and i pulled those rca's out, it would cut the music out. i think i am going to order another one and hope it is that little box.
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
6
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
7K
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
6
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
530
mrToester
mrToester
Southern JErsey, next to philly
mrToester
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
