I'm new to taramps (and full bridge) but I got smart 3 installed...I've been running it about 2 weeks now and a couple things strike me as odd...
The fans start up when i power on but shut off right after...every other amp I've had with fans either stayed on when powered or never came on til the amp got hot...so I'm not sure if this is normal...
The other thing is the gain...even when turned all the way down I get good movement from my subs...they're rated 1200w for the pair and I got them wired to 4ohm...I'm figuring since the amp produces quite a bit more power then the subs need is why...but again this is the first amp I've own that turning the gain all the way down didn't effectively shut off the subs...
Everything sounds good...no floor noise from the amp...the subs are clean sounding...those 2 things just strike me as odd so I figured I'd ask...
