crossover
  • 2
DaRevrin
Im dont really know much about these but my old hifonics 6 channel amp, its a zed amp... has a crossover with it. Ill be using this amp for my door speakers. I have an amp for my sub also.
What is the point of the crossover and do i need to use it??
Yes you'll need to use one. A crossover keeps unwanted freqs away from a speaker.
Subs can't play 10kHz, well they can but it's not good, and a tweeter can't play 40Hz. If a tweet plays 40Hz it will mean certain death to the tweet. A mid range speaker can't play as low as 40Hz nor can it play as high as 10kHz, so it needs to stay between that say, 80Hz -3kHz.
Subs are intended to play ~100Hz and down
Mids are intended to play between ~80Hz - 4kHz
Tweets are intended to pay ~2.5kHz and up
So to keep them playing their intended freqs, you'll need to cross them over, or filter out those freqs that are harmful to that certain speaker.
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
307
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
990
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
DaRevrin
DaRevrin
Memphis, TN
smgreen20
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
