Current build, suggestions for whats next?
  • 2
Iskavan
23
Maine
The above vid is my current build, four earthquake tremor 12's running at 1500rms 1ohm. Ive since fiddled with the amp a little and found better sounding songs, so my bass its a little higher, video is still a good taste of my setup though.
I was thinking of getting four earthquake magma 12x's or eight PSI 8's, I dont want to spend anymore than a 1,500$ on subs, and i want to keep it around 2,500rms, i can double it if i must but would prefer not to. I want to keep the enclosure no bigger than 12 cubes. I am really pleased with my current build, but the possibility of being louder constantly nags at me. Any suggestion on amazing budget subs please feel free to respond, also which would be better, eight 8's or four 12's.
honestly i don't know if that BP is actually hitting that hard. and that amp is definitely not the greatest. before you spend more money on something you might beable to improve what you currently have..
im pretty sure 4 12s with 1500 can get well into the 140s.. should be close to 145.. your trunk is acting like another alignment as well. its more than likely acting like a 6th order series BP.
the magmas arent what htey used to be and erathquake used to be the bomb with those magmas..
I have not gotten it metered, but from listening to other peoples setups, and how much this makes my eyes shake i am 100% sure im in the 140s. My ears feel like im underwater, and the guard rail on the side of the road bounces. I tested the amp, max output is 2675 at 1ohm, only putting 1500 to the subs, i can push it to 2,000rms but the subs start to smell after 15ish mins. I know the amp is not the greatest, but for the price its amazing.
Been looking around and i think a single 18inch psi platform 4 would do what im looking for. Would the Soundstream T1.6000DL be a good fit at .5 ohm?
any suggestions on tuning and box type?
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
5
784
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
5
If you have not already done this, do a thorough job of sound deadening the doors before spending a lot of money new equipment. This is probably...
4
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
983
Iskavan
Iskavan
Maine
Iskavan
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
