debating on 2 different box designs
  • 2
eenyuheye8o8
I was debating which box design would be better. Would be a ported enclosure facing into cabin in the trunk and sealed off. So port and subs facing into cabin. Or a 4th order. Both boxes will be built in the trunk. What I am trying to achieve is good over all sound, be able to hit a good amount of notes but hit really good lows also. More of an SQL build. Can't decide on what box to go with.
What subs, and vehicle, and amp?
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
12
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
eenyuheye8o8
eenyuheye8o8
Mililani, Hawaii
eenyuheye8o8
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
