Design Help Please: 15" TC 5200 in 4 Cubic Ft @ 28-32Hz
Bwap
NY
Vehicle : 2001 Volvo s80
Location in the vehicle: Trunk (Possibly forward facing?)
Space available (Depth x Width x Height): 14.5"D x 39"W x 16"H (All measurements are MAX)
Subwoofer make and model: TC Sounds (TC-5200)
Subwoofer Size: 15"
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): Slot (Will do Aero if needed)
What type of music do you like?: Dubstep, Electro, Classic rock, and Rap(for lows don't care for the music).
Is your goal SPL or Everyday Music?: Im looking for an in between, I love SPL but need definition between the sounds. So more like an SQL setup.
Tuning Freq (Hz): 28-32Hz is what I have been recommended for this sub. Although I am very open to opinions.
Volume: 4 Cubic Ft
Amp: Mmats 3500.05 at .3 or .6 ohms. (Input needed as well, adding 30% resistance for nominal would leave me at .4 or .8)
Questions: I have a few dilemmas with this build for the following reasons:
1a. The max depth I have to work with is 14.5", after accounting for the 1.5" of MDF, im left with 13" of mounting depth for the sub. The TC 5200 has a mounting depth of 11.5", leaving only 1.5" of clearance behind the sub. Would there be cooling issues with the sub because of this?
1b. Would adding a sheet of MDF to the front of the box where the sub is being mounted fix/help with the issue by adding .75" for a total of 2.25" of clearance?
2. Does anyone have any input on the tuning of the box?.. I have no experience with these drivers, I was recommended this range for tuning. TC recommends 21-34hz tuning.
3. I have built 5 boxes in the past, all slot ports, tuned 32-40. Because of my depth restriction I may have to do an aero port this time, any reason I should opt away from aero ports?
4. Also I have been having a hard time deciding whether I should aim the subs into the cab or not. If you have experience with both, what did you prefer?
Any input is very much appreciated, thanks in advance. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I can design on for you. You need a significant amount more of space though.
Its the absolute largest that can fit in the car.. I made a box the exact dimensions for 2 12s. I had to gut the trunk, floor mat, spare tire, battery, just to fit it in. It wasn't easy either, had to be rotated all over. :/
There isn't a way to make an adequate box for that sub with those dimensions? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
You barely have 4 cubes without including sub or port displacement. You could go sealed if you wanted. You may only be able to get 3.5 cube with a 6" aero ported, but it'd have to side fire to fit without bending for proper tuning.
You barely have 4 cubes with sub or port displacement. You could go sealed if you wanted. You may only be able to get 3.5 cube with a 6" aero ported, but it'd have to side fire to fit without bending for proper tuning.
Side firing in some trunks isnt' too bad. I'd probably go small on a 5200 for daily, they have so much motor force it's kinda hard not to get a 1 note wonder sound out of them. Sealed would be great though in terms of space. Q is so low on those things you can basically build the box as small as you want without messing with the actual frequency response too much. 1.5-2 cubes sealed would be big enough and take up very little room. With his music preference, unless he really wants every db he can squeeze out of it I'd try a small sealed box and see how it goes.
Ya, these are different than a lot of woofers in sealed, they still reproduce nicely.
Hmm that's rough, I haven't heard a sealed sub that I have been impressed with. I know this sub is very different from those Ive heard tho. Idk what I want to do now, I am impressed with the stats of this sub but idk if I want to go the sealed route. What would be the ideal sealed size?.. would only having an inch and a half of space behind the sub be a problem for cooling?... and how much power will it take sealed? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
My 5200 18 did very good for me in about 4.5 cubes.The space you have might not be too bad for the 15.
Yay, a light at the end of the dark tunnel haha.. Can you tell me more info about your box?..
What was it tuned to?
Was it 4.5 cubes of air space after displacement and port area?.. (or 4.5 cubes total?)
Or was it a sealed box? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
7093= Total internal volume(port included) (4.09cubes) 39W x 16h x 14.5d
1218= Area of port (.70ft^3)
285= Displacement of MDF
260= Displacement of sub
5330=total air space for sub (3.08ft^3)
Tuned to 32hz
port dimensions - 26.5D x 3.5W x 14.5H
2nd Port option:
Tuned to 34.4hz
Port dimensions - 26.5d x 4W x 14.5h
Area of port = 1537inches^3 (.89ft^3)
Would either of these options work?.. would there be port noise?... am I better off sealed?
Tune as low as you can without losing too much internal space.
copy/paste from site you linked:
15TC-5200
Type Volume Tuning Fq Area Port/Pass Length / Mass
Sealed less than 1.0 ft3 NA NA NA
Ported 3.7 ft3 21Hz 25 in2 31 in
Passive 3.7 ft3 10Hz-25Hz Dual 15" PR Variable
And this is what Thilo called a 'Large" box
7093= Total internal volume(port included) (4.09cubes) 39W x 16h x 14.5d1218= Area of port (.70ft^3)
Tuned to 32hz
2nd Port option:
Tuned to 34.4hz
Anyone have any idea how a box like this will sound or should I tune lower?.. also do I need even more port area?
im debating just getting a 15" psi passive radiator and trying that out... according to winisd id only be losing about 1.5db and would completely avoid port noise/turbulence... also it seems a 20-23hz tuning allows the flattest response with this driver.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
744
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
5
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
Bwap
Bwap
NY
Bassman999
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
