Design Question For Sundown Audio sa-12 Rev3
  • 2
Mozilla214
Vehicle :Hyundai elantra 2005
Location in the vehicle: in the trunk, port and sub facing towards trunk
Space available (Length x Width x Height): 35" deep, 34" Wide, 19" Tall
Subwoofer make and model: sundown audio sa-12 Rev 3
Subwoofer Size:12"
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): slot
What type of music do you like?: rap
Is your goal SPL or Everyday Music?: everyday
Tuning Freq (Hz): 34Hz
Questions: 1. What would be a good cu feet when im going to run 1100rms on it (alpine mrx m110 Alpine )? i was thinking 1.7?
2. when designing, i want to add 45 degree corners. if i add them AFTER designing the box to the recommended cu ft(like not including the 45 angle corners in the blueprint) , will it greatly affect the cu ft of the box?
3. i want to tune my box to 34Hz( or any other recommendations are welcome) , and the subsonic filter on the amp only goes up to 30, how will i go about adjusting that?
All depends on the size of the 45s but yes it will change net cubes as well as tuning.
Sent from my SM-N920V using Tapatalk
---------- Post added at 06:19 AM ---------- Previous post was at 06:18 AM ----------
25ish would be your ss setting....34x.75=25.5
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
448
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
780
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
718
Mozilla214
Mozilla214
Dallas,TX
CSCStang
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
