Difference between 2 12s and 1 15
15=176.62 sq in vs 2 12s=226sq using the math already done we can infer that
2 15" = 352 sq in
3 12" = 339 sq in
so closer in cone area than before.
you should be able to do that math.
The flaw in your logic is assuming that the 17" sub with at least twice the moving mass of one of the 12s will move as far with 750w as one of the 12s would. The fact is that it wouldn't assuming the same motor force (same motor). It would move half as far and thus have half the swept volume for a theoretical decrease of 3dB in output in a sealed enclosure. You'd have to through 1500w at the big sub to get it to move as far as one of the 12s with 750.
I see your point, but how come the larger subs are not given a higher rms rating then their smaller brothers when they share the same motor? I know their is the heat aspect of it but i'm assuming there are subs that reach their mechanical limits before their thermal limits so why no increase in rms?
some companys do increase the rms in size
If a 17" only moves half as far for a theoretical decrease of 3db, why would a 17" sub on 750 watts be louder than a 12" on 750 watts?
but the cone only moves half as far according to the other post. (double cone area --- 3 db increase, twice moving mass --- 3db decrease, so their should be no gain?)
The difference between 2 12s on 1500 watts and the one 17" on 750 would be 3dB. If you were to compare the 17 on 750 to a single 12 on 750, the difference would be 3dB with the 17" being louder. With the pair of 12s you have twice the surface area (+3dB) with twice the power (+3dB) compared to the single 12. With the single 17 you only have twice the surface area. The bigger sub is actually going to move more than half as much as the single 12 on the same power because of the non-linear nature of the BL curve and suspension compliance (at higher excursion the motor weakens and drives the cone with less force and the suspension stiffens up as it approaches its limits). The pair of 12s on 750 total would be louder than the single 12 on 750 as well.
Remember that this is all theoretical. The pair of 12s would still have an advantage in output and SQ because of power compression. That might be slightly reduced by phase cancellation because of slight variances in the exact specs of the pair of drivers. Also the larger cone of the 17 with 2x the Sd will probably weight more than 2x that of one of the 12s making the difference in efficiency less than 3dB as well.
First of all to understand what happened to killer, you gotta understand who killer the dog was. Now killer was born to a three-legged ***** of a mother. He was always ashamed of this, man. And then right after that he's adopted by this man, Tito Liebowitz he's a small time gun runner and a rotweiler fight promoter. So he puts killer into training. They see killer's good. He is **** good. But then he had the fight of his life. They pit him against his brother nibbles. And killer said "no man that's my brother, I can't fight nibbles" but they made him fight anyway, and killer, he killed nibbles. Killer said "that's it!" he called off all his fights, and he started doing crack, and he freaked out. Then in a rage, he collapsed, and his heart no longer beat. wow.
Alright, i think i understand now.
Somewhat offtopic but not really: Is their a reason that you can fit so much more cone area in a box when using multiple small subs?
Example:
10" FI Q has a max recommended volume of .6ft^3 for a sealed box.
15" FI Q has a max recommended volume of 2.6ft^3 for a sealed box.
In the size of the 15" box (2.6ft^3) you could fit 4 10" subs.
15" ~ 176ft^2 cone area
4 10" subs ~ 314ft^2 cone area
How come you can fit such a large amount of cone area in such a small volume when using multiple small subs?
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
383
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
772
newyork2050
newyork2050
ny
helotaxi
Decebal
    Jun 10, 2024
