Difference between a 2 or 3 way speaker and a component
  • 3
I’ll say it depends on where the comparison is made. In a vehicle having the tweets separate gives depth to the sound stage. Different vehicles have different layouts sometimes making it challenging to get the best sound. If you’re driving a 70 chevelle go for 3ways in the front doors and 2ways on the back deck. Almost all vehicles having separate components are replaceable w better ones of the same size. Example.
If you were outside, cut a hole in plywood and mounted a 6.5 full range then compared a 6.5 w a tweeter next to it, stood there trying to decipher a difference in sq it’d be hard. In a vehicle if the full range is blaring into your knee you definitely lose some highs of the tweeter. Having the tweeter higher and reflecting sound off the windshield or coming from either side the sound is free to hit your ear holes.
I can hear the difference. A typical component system will have a superior tweeter and crossover, although I've noticed component crossovers are getting crappier and crappier.
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
Just thought I'd quickly update this thread as it's been a long while since I promised an update, I finally checked the AC output of the speaker...
23
6K
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
197
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
ianik777
CarAudio.com Regular
ianik777
Mauritius
Jimi77
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
