dilemma- Keeping current vs replacing
  • 1
Kid Red
I can't seem to make up my mind and I'm looking for some opinions. Bare with me for a few please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I currently have a TC10 OEM powered by a Sundown 1000d and Cadence CWM components feed by a Sundownz 100.2.
The TC10 needs at least 800w but is a D4 so I can only get 600w from the Sundown. It sounds so good but I have the Sundown's gain set high and the sub only slightly gets moving. It's in a .75 exclosure I believe, and I takes up too much trunk space. I want to put it in a FG enclosure but it's such a large woofer I don't think I'd have much clearance to work with (keeping the spare tire floor free to open) I want the entire floor of the trunk clear and free.
The 100.2 has a 75hz crossover and I'd like to get a little more from my fronts, 50hz-65hz or so for a little extra presence. Lastly, there is the issue with mounting/installing these in a clean, presentable manner. Currently, the amps are installed on the back seat and that is temporary until I got the amps mounted on an amp rack. However, the two amps are just too big to keep out of the trunk main space so the seat back was the only thing I could think of temporarily. I want the amps under the deck or on one side of the trunk, together in an amp rack. I can't do that with these amps without having one on the side and one on the deck.
So I was thinking about a few options.
If I keep the TC10, and barely fit a FG box in the side pocket, I'd need a 800W+ @ 4 ohm amp at least. The PDX 1.1000 was my first thought for output and size. Then I could match with a PDX 150.2 or 150.4 if I ever get brave enough to go active.
-I get an IDQ10 or 12 D4 which is less 6" deep and mount it effortlessly, and the keep the sundown which will be unfortunately be difficult to mount/hide cleanly.
-I get an IDQ10 or 12 which is 6" less deep and mount it fine, and the PDX amps which are small (PDX 1.600 & 150.2) which could go anywhere due to size. If yes on the IDQ, but no on the PDX, then I need to know what DVC to get to match whatever amp.
-I also have an Alpine MPF250, that I could run my fronts, and then get the Alpine M1000 to run the IDQ D4 assuming I can wire it to stay at 4ohm or for the TC10? I'd have to mount these separately, but this is my cheapest option. Or get a IDQ D4 and get the Alpine M500?
So, I don't know what to do. If I keep the TC10, I need more power. If I move down to a 500-600w sub that is less than 6" deep, I believe I'd need a D4 to only get 600w from the Sundownz which still leaves me wondering where the amps go.
Ideally, I get the IDQ12 and PDX 1.600 and PDX 4.150 for the fronts. But the TC10 is sooo sexy, and such a smooth deep bass sub that I'd hate to replace it and be disappointed. Plus, there might be better SQ-that-get-low-subs that are less than 6" deep and I am just ignorant to those options. Sub enclosure would be ballpark .85 or so sealed.
Budget is within reason, $250 or so for the sub, and $300-$550 or so per amp where size is very important. I really want smaller amps, the JL HD series is intriguing, just at the rich end of the scale.
I hope no one feels I owe them 5 minutes of their life back after reading this long winded inquiry, but I'd like to hear a few opinions more experienced than mine. I want smaller amps and a more shallow sub for easier mount. However, I don't want to do it if I will lose anything based on what I currently have. (Please forgive me if I screwed up any ohm or wattage ratings, etc, I don't claim to be very audio versed)
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
5
857
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
5
If you have not already done this, do a thorough job of sound deadening the doors before spending a lot of money new equipment. This is probably...
4
Kid Red
Kid Red
Orlando, Fl
Kid Red
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
