Distance from port to back wall
CadillacMatt
Disturbing the Peace
I realize this has been discussed a lot, but I usually find many answers to this question.
The general consensus of 1/2 dia. of port distance from the rear wall is acceptable, right? I just wanted to get some second opinions before I chop my port tube down any.
As it stands, I will have anywhere from 3.5" to 4" of distance to the rear wall, would this be fine for an 8.75" port? I realize it's a little less than half of the port diameter. The back end WILL be flared, if it makes a difference... and it's an 18" woofer in about 6 cubes of space.
Thanks!
Pic: This is the setup, port hasn't been trimmed yet.
We did 4 3512's in a Tahoe and the port was only about 2 inches away from the rear wall. It definitely still got loud. You could always just see how it effects sound just by moving it back and forth.
Yes it is, it has significant difference. I replaced my Mercedes head unit with the pioneer dmh-z5350bt, and I noticed that the built-in amp on...
10
thanks for the responses, I have an Alpine iLX-705D ( iLX-507 in the US) which has some inbuilt time alignment and fairly advanced EQ.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
695
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
868
CadillacMatt
CadillacMatt
San Antonio, TX
Buck
    May 16, 2024
    May 16, 2024
