Distortion When Trunk is Closed?
  • 6
Hunter079
So I have a Polk dxi 124 DVC subwoofer inside the trunk of my '91 Honda Civic. I have set the gain so that it sounds great with the trunk open, but I noticed that as i close the trunk I can hear it distort. Is there a way to fix this issue? The enclosure is ported by the way and it is firing towards the back of the car.
Distortion is introduced either by the audio source, HU, or amp. You can have distortion without a speaker even connected, so what you're hearing is not distortion; you're hearing something else, like rattles or resonating metal panels coloring the sound.
The distance from the port opening to the surface it's facing will affect the sound. Try playing with the distance between the box and the trunk lid.
im betting its something rattling in the trunk and not the subs making the noise. play a frequency sweep from 30-80 hz or so and when you hear the rattle stop at that frequency and keep playing it until you find where its coming from
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
7
981
Hey guys, anyone with a DD-1 or other distortion detector in the south florida area ? Thnks
The amplifier will only amplify the waveform that you put into it. I think you have missed or are misinterpreting something here.
12
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
932
Hunter079
Hunter079
United States
TaylorFade
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
