Newbie question, is this amount of noise normal?
Hello all, relative newbie here, just got my hands on a Sundown Audio X-8 D2, and was checking her out.
Got it hooked up to an SoundQubed Q1.2200.D v1 at 1 ohm.
When I turn up the volume a bit, there is quite a bit of noise coming from the pole vent.
I was curious if this was normal for this subwoofer, so if you happen to own one would you mind chiming in?
https://youtu.be/n54YjjFsE9o
https://youtu.be/dxiYH8YZx64
TIA,
spud
I just got my d4 x8's in box today and noticed a similar noise... Got me thinking wtf... While I was trying to listen to it amp got stinky and smoked on me
You know, once you let the smoke out of electronic equipment, it tends to not work anymore //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That ***** your amp blew, what kind was it, and how did you have it wired up? Sounds like you had the ohms too low...
If the question is did I pick it up from a yardsale, no I did not, it was purchased new off of amazon, via woofer etc.
---------- Post added at 10:20 PM ---------- Previous post was at 10:19 PM ----------
I can't say *****? ***** ***** ***** s u c k s
only triple OG's can curse. After '10 they wont allow it. fuck shit bitch
Yard sale?
Mine came from emf
1ohm Orion xtr2200.1d.... I'm trying to figure out wtf caused this... Was listening for leaks around my subs and the slap sound when I smelled my amp... Wasn't even at full tilt... Mid volume... Could it be a ground issue?
Reply in my post Orion xtr2200.1d 25min amp
Not trying to thread jack here my bad
yeah no speaker practically will be quiet at full excurion free air. You won't hear that when the subwoofer is mounted in the box, not only because of the noise being inside the box, but the volume of the bass will mask it as well.
You think those few vids he had was at full excursion perhaps you need to borrow my glasses.
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
3K
You could control the radio from your phone but that's about it. I do not think you can, but if you could, for on screen phone it would have to...
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
930
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
Spudicus
Spudicus
St. Pete, Florida
Spudicus
