DIY alternative to glass antennas
  • 2
installerblizz
I drive a 2007 Accord that has the radio antenna embedded in the rear glass. My deck is a Pioneer 880PRS. I had horrible reception even with power going to the stock antenna booster. I read about the universal window mounted antennas but people were saying that nothing beats a good old mast antenna. Not wanting to drill holes in the body of my car, I tried to find one with a magnetic base without luck. I decided to build one. It looks a little rough now, but I'm going to paint it eventually. It's basically 31" of coat hanger straightened out and stuck in and soldered into a 20 lb pull magnet from a hardware store. I used TV coax cable to make the connection, and the shield is grounded at the antenna plug on the deck and at a bolt that helps hold the front quarter panel on. The 880 shows signal strength on a scale of 0 to 4. I couldn't pick up half the stations in my town with the factory antenna, but now every one of them is a 4! It's unreal. Anyway, thought I'd share it with you guys. If you wanted to spend more than $3 like I did, you could get a mast antenna from a junk yard instead instead of a coat hanger.
What exactly about my solution do you find improper? I wanted a mast antenna and didn't want to drill holes in my car. I don't know of any other Earth technology besides a magnet that would have allowed me to do this.
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
4
installerblizz
installerblizz
Tupelo, MS
installerblizz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
