My title pretty much sums it up. I'm wondering if my class d mono amplifier will lower the ohms the same way bridging does. My understanding is that, let's say you bridged a 4 ohm subwoofer, you then would be running that subwoofer at 2 ohms. Correct? So does that rule apply for class d mono amps as well? I currently have two dual voice coil 2 ohm subs and they are wired in series up to 4 ohms and running on my mono amp. I want to wire them parallel for a 1 ohm load but if the ohms are dropped again at the amp I do not want to burn up my amp by running it at .5 ohms. Help me out
