Do I need a relay?
Syphlyn
Canada
hey guys just doing my system soon and am wondering if it's worth getting a relay for my remote wire.
I'll be running my Alpine PDX-F4/Sundown SAZ-2000D/Stinger SVMB volt meter off the remote wire. I havne't installed the volt meter yet. I'm just wondering if it's worth getting a relay or should my headunit be fine without one? I just don't want to stress it too much.
Currently looking at this: CE Auto Electric Supply - Turn-On Relay Kits the second one. It looks professional and has some great reviews plus I get a 10% discount for being apart of SMD forums!
The CE relays are nice imo, already wired up to make your install as clean as possible. If you want to save a few bucks, any SPDT relay will work.
they aren't $17+ nice. all it is, is a relay, an inline fuse and a couple pieces of wire. $7 total.
And if you want to get the terminal strip, another $1
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
139
192
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
501
Syphlyn
Syphlyn
Canada
bradl79
audiobaun
    May 19, 2024
    May 19, 2024
