Do I need the Big 3 upgrade vs a second car battery? 06 Audi A6
willspeedjr
I'm having some slight electrical problems that show up when I jack my bass up, no problems when I want a nice little thump to my music. I've been told to get a cap, which doesn't provide extra power but just streamlines the power. Whereas a second battery will give it more power. Do I need to do the big 3 upgrade before a second battery installation? Does my A6 already have a high ouptut alternator, which means I don't need the big 3 upgrade? Does the second batt have to be the same specs as the factory one, can the specs be higher than factory batt specs or can the second batt specs be lower.
CAR: 2006 Audi A6 3.2L Quattro w/ Bose/DVD Navigation
AMP: NVX 1200watt RMS JAD 1200.1
SUB: NVX VSW124 400-600 RMS (its wired to pull 600 watts of RMS, just one tho)
it really depends on each car individually , most can take 2000 rms with just a big 3 kit ,and its the cheapest way to tighten up the electrical .next would be an extra battery then alt.chances are your stock alt isnt a high out put alt
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
127
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
187
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
141
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
494
willspeedjr
willspeedjr
Dallas, Tx
SplAffair
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
