Do i need to replace my OEM alternator and battery?
  • 2
alecrfreeman30
CarAudio.com Newbie
I'm about to install a 12" Sundown Xv2 D2 1500wrms ran by a wolfram w3000.1(yes, I know the amp way overpowers the sub, but it was free). Just curious if that's considered too much power for an OEM electrical setup. I Was going to do a big 3 (4) upgrade too but wasn't sure if that would be enough. Thanks.
Stock alt size is the biggest factor. Listening habits are a major factor also.
Regardless, even if your stock alt is strong, that's generally because the stock electrical load is fairly heavy too.
What is known is the workload on the alt will increase substantially. Which means more wear and tear (more heat) and a shorter working life. Whether that will be 10% shorter or 75% shorter is the unknown.
They are sized to run at ~50% capacity for ~100k miles. Obviously, if you operate them at 75-100% capacity that 100k will drop fast.
Generally, I say install it and see how it runs. With a 3k amp and a 1.5k sub I wouldn't expect you to be leaning on the amp too hard very often so it may run ok. But be prepared for the alt to fail a lot sooner than most factory alts.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
344
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
298
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
675
11
545
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
alecrfreeman30
CarAudio.com Newbie
alecrfreeman30
n2audio
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
