Do I Need To Upgrade My Electrical?
  • 3
ekah
hawaii
Do I Need To Upgrade My Electrical if im going to be running a 2k amp in my car? i have a Nissan Versa 08 hatch and wanting to get a sq HDC3 and maybe a BASS CLEF SERIES BC2000D to run it. As im closing into getting everything custom box and everything i see people upgrading their electrical. alternator and a Separate battery or is that for like the more hardcore sounds? or would my stock alternator be sufficient? would my car blow up and make a hole in the earth?
I'd say you'd probably need to. Most cars adding anything more than 1000 "real" watts will cause electrical issues. If it were me, i'd do the big 3 when you do your system making sure that your grounds are as solid as possible. Then go from there.
iv seen people say "the big 3" but have no idea what that is? electrical meaning like dimming lights? and maybe cluster and hu dim?
The big 3 is upgrading your charging cables under the hood that go to your alternator and grounds to the battery and engine block. There's a sticky on it in the forum. But yes, i'd be willing to bet you'll have dimming lights inside and out. But like i said, do your system with upgraded charging cables and if your voltage still drops a lot then look to do your alternator and possibly a battery.
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
they don"t have anything for the G8, and my problem with the install kit is the hvac part. i dont like the physical controls on it, hard to operate
4
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
8
ekah
ekah
hawaii
DaytonLax14
winkychevelle
    Jun 3, 2024
