dsp or aftermarket radio
  • 1
You cant go wrong by adding anything to improve sound quality
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
887
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
674
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Mr.Jackson
Mr.Jackson
Stone Mountain Ga
Mr.Jackson
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
