DSP
  • 2
Tarron91
CarAudio.com Newbie
Hey everyone! So i have (2) Sundown X3 dual 2 ohm 12 inch subs that I'm getting installed in a 2015 impala LTZ. So far i have the amp (Cerwin Vega CVPRO5K), subs (of course), big 3 upgrade (installed), 400 amp alternator (installed), and LC2i Pro 2 channel line out converter. I have been told i should invest in a really good DSP. There is a lot different brands out there but I'm willing to spend the money on a good one. I'm keeping my factory speakers (for right now). I'm actually taking this to a local good rep car audio shop to let them do the install but wanted to get the DSP first so i have everything. I'm still new to trying to figure out how to use it. I know they help fine tune your system. Can you all recommend a really good one?
Thanks in advance!!
I would wait until you get your system completed. The LC7i PRO has a built subsonic filter at 22hz and until you get the rest of what you will need to complete the setup, getting DSP just for the subs is a waste of money, It will not be used in conjunction with LC7ipro as a dedicated or embedded DSP control will likely supplant it.
When you know what the new speakers, possibly a new HU, amplifier(s) etc. then get the DSP unit to tune the car. With stock speakers and stock power to those speakers, really no point.
Additionally, many multi channel amplimers are now inbedding DSP controllers too, so again, you should wait to see how that pans out.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
711
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
472
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
439
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Tarron91
CarAudio.com Newbie
Tarron91
st louis
Doxquzme
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
