Dual 12 inch Audiopipe Ts-Pr's With Lightning Audio amp. Need help.
Audiopipe TS-PR12BL TS-PR Series 12" 750 Watt Blue Subwoofer, 750 Watts MAX Power, 375 Watts RMS Power, Frequency Response 22Hz - 100KHz, Sensitivity 95dB, Rubber Surround, Blue One Piece Metal Cone, Candy Blue Painted Steel Basket, 2" 4 Ohms 4-Layer Dual Voice Coil, Conex Spider, 60 oz. Magnet. I need a way to wire each sub to a 4 ohm load and i have no idea where to start.
If it is a Dual 4 ohm subwoofer as stated in that description, EACH subwoofer can only go to either 2 or 8.. Both subwoofers combined however, can achieve a 4 ohm load.. What exactly do you need? What amp are you trying to use?
Sigh...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
188
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
507
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
954
westwest9994
westwest9994
Bolivar Missouri
