Dual alt bracket
mylows10
B2,singer,ampere rep
22,678
monterey , ca
Dual alt bracket. Late model Chevy gmc for passenger side application I know it fits the 5.7 and 4.3 for sure
Used in good shape. Has belt to
$200 firm
USPS flat rate
778
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
796
892
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
mylows10
mylows10
monterey , ca
mylows10
Brendon Jenness
    May 8, 2024
    May 8, 2024
