Dual Amp and Power Wire Size?
  • 2
bossman_19
Two amps.
1. Rockford Fosgate R500X1D Class D Mono Block----------For my 1 RF P2D2-12 sub
•RMS Power Rating:
◦4 ohms: 300 watts x 1 chan.
◦2 ohms: 500 watts x 1 chan.
Says use 4 gauge.
2. Hifonics ZRX600.4 A/B------------------ Running 4 6x9s
•Max Power Rating:
◦4 ohms: 75 watts x 4 chan.
◦2 ohms: 150 watts x 4 chan.
◦Bridged, 4 ohm: 300 watts x 2 chan.
•8 gauge power wire to use
So how big should the main power wire be? 2 gauge? Then into a DB with 4 gauge going to the subs amp and 8 gauge going to the speakers amp both like what they recommend.
Or could I go 4 to both amps from the DB from the 2 gauge main power wire?
Or can I just run 4 gauge everywhere. With fuses in the main wire, then after DB one in each power wire? Just worried that its too much power going into one wire.
Just need a clear path to take and go from.
I already have a 8 gauge wire kit from past hook-ups.
I plan on doing this my self so don't tell me to get it professionally done...
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
951
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
143
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
855
bossman_19
bossman_19
St.Louis
Side Show
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
