dual batteries?
  • 5
<v=rus>
22
Eau
I plan on running four 15's at about 700 RMS from two 2400watt Amps. I also plan to use the stock speakers from the headunit and then add a four-channel amp and get a total of 8 speakers, 2 tweeters, and 4 subs. Besides upgrading my alt. should i run a larger power cell or connect a second battery?
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
527
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
698
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
999
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
935
<v=rus>
<v=rus>
Eau
BassAce
