Dual DVC-2-Ohm in different sealed enclosures
THIS
IS THE SAME AS THIS:
One coil + to the other coil - (on each).
The other + & - to the terminal block.
Terminal blocks wired straight to the amp, connect the wires at the amp terminal.
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
174
873
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
851
Trenton04
Trenton04
South Carolina
HardofWhoring
audiobaun
    May 19, 2024
    May 19, 2024
