Dual Sundown E8 V5 Questions
  • 3
AdamC
19
Indiana
Heya guys , I have a few quick questions and I'm hoping you all can point me in the right direction .
I'm switching over to a set of dual E8's with a SAE600D amp and the real question I have is , is on the HZ specs . According to Sundowns website these should be tuned to 32 HZ , however every box I find is in the upper 30 range . Will a box tuned at 37 really make that much of a difference ? I'm no fabricator by any means so I'm looking at prefabs since mky wood working and building skills are garbage unfortunately .
On a side note , how do you think this setup would sound and perform ? I've seen some dual 8's really knock at lower wattages in the past . I appreciate your responses !
Prefabs are not optimal. Post a link to what you are looking at. Maybe someone will design and build one for you cheaply. Tuning should based on other things like music preferences and what you want out of your setup.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
157
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
467
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
947
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
892
AdamC
AdamC
Indiana
THATpurpleKUSH
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
