Dual system hook up how to help
  • 2
bigblockchevy13
I'm new to the audio world but have a good understanding of it. I'm planning a build for my truck and I want to have 2 sets of speakers and sub. One set of speakers and sub in the cab and another set of speakers and sub for exterior sound using one head unit. I would love to be able to fade between the 2 but not necessary but I will need to be able to switch the exterior sepeakers off and on. I have a Kenwood KDC-BT858U head unit. It has front, rear, and sub RCAs. I want full sound quality to both. Anybody know how I can achieve this? Is it possible?
Y-splitters on RCAs and Toggle switch on remote wire for external speaker amp. Or use the passthrus on your main amps
Sent from my 5054N using Tapatalk
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
387
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
603
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
977
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
922
bigblockchevy13
bigblockchevy13
florida
bigblockchevy13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
