DVC Help
  • 4
So this is my first post in here. I've done quite a bit of research on wiring diagrams in regards to wiring my sub. Currently, I have a kicker DVC 4 ohm 12" sub I'm running off a 2 channel amp that I have bridged. I'm running the wiring in series so my amp is seeing 8 ohms. I have a couple of questions.
1. How the heck do I tell which positive and negative terminal goes to each voice coil? I've looked at the bottom of the speaker and they don't seem to be marked. Not only that, but they are spaced equidistance apart. I looked on the kicker website on their wiring diagrams and tried to wire them accordingly, but their terminals didn't really match up to the picture.
2. In bridged mode I can't go below 4 ohms. So, should I run a sub off each channel with their voice coils wired in parallel @ 2 ohms or should I run the pair off the amp in bridged mode at 4 ohms?
thanks in advance!
thanks in advance!
I'd run it bridged at 2. With box rise it won't see that low very often just make sure the amp doesn't get too hot
Sent from my 5054N using Tapatalk
That's interesting. Never heard of a sub terminal not marked. Either have a red mark on there(which will stand for pos,+) or a stamped "+" on the terminal. Usually cheapy subs have the + and - stamped on the terminals. Take a pic of the sub and post it up here. Some subs have that red mark and black mark.
What amp do you have?
I have a crunch 1000.2 bridged. I know it's not the best amp, but I can't upgrade for a while. The terminals are marked "positive and negative" just not marked as to which voice coil they belong to. That's where my confusion is coming from.
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
192
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
4
randymessman
randymessman
Fort Worth, TX
n2audio
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
