For my sub amp Does this mean balanced input or is this different?
  • 1
ccapital83
NY
installing my Rockford Fosgate RF-BLD tomorrow. Im going from hi level oem woofer into the Rockford Fosgate RF-BLD then out from that via rca into my aftermarket amp. The Rockford Fosgate RF-BLD has a switch for balanced and un balanced. I cannot tell if my amp will accept this balanced. I want to make sure the switch is properly set. I know the amp accepts up to 20v and the manual states its differential. I googled this like crazy its I cannot get the exact answer. Here is a pic from the amps manual explaining it. Hopefully this makes sense and someone can tell me weather or not I can use the balanced switch on the Rockford Fosgate RF-BLD.............
262
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
788
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
853
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
895
ccapital83
ccapital83
NY
ccapital83
