Eclipse CD3200 HU screen help please!!!
  • 2
Chollis
I recently purchased an Eclipse CD3200 and about 20 minutes into messing with the EQ and such after the install, the screen started to fade slowly until it was all black. Now, the 4 main buttons work, but the screen is black. After checking and double checking to make sure that it wasn't something with my wiring, I thought that maybe the screen just burnt out. I got a replacement faceplate, but it's still doing the same thing. Is there some specific part that usually goes out on these things? Has anyone ever run into this problem with this head unit, or this problem in general? Is there something in the receiver that blew or needs to be replaced? How can I fix this? Please help me out, give me some clues as to what it could be...
I just sent my CD3200 and faceplate to United Radio in NY for similar symptoms. Faceplate buttons seemed to work, but display was black. They reported that they couldn't fix it as apparently there were burnt out components in the HU. I'm curious as to where you found one to install at this point? I found your post as I was just online searching to see if there were compatible Eclipse HU's that might fit the same opening and possible use the same Lan and main rear connectors. I'd like to keep the Sirius/Ipod/amp setup. Anyone know if there are newer Eclipse HU's that might work? It would be even better if someone really could fix these HU's.
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
881
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Chollis
Chollis
Los Angeles
lapycaraudio
    Jun 1, 2024
    May 31, 2024
