electric eq and 2nd amp wireing
  • 2
fordnut78
hi to all im stuck at the moment on how to wire an eq and 2nd amp,i know i need to use a relay .my question to all is could i put the relay in the back of the car and split it from there or do i have to wire it in the front close to the battery ? Ive always had it close to the front but as im installing the above into a ford focus i dont want to drill any holes ,but if i have to i will any help would be appreciated
thank you
You only need the relay if its not strong enough to turn everything on..is the eq by the headunit?
You can tap of the lead in the back for your other amp too...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
359
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
fordnut78
fordnut78
united kingdom
fordnut78
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
