Is my amp gonna over power the sub?
  • 2
Mack199
I got a Kicker solo baric L5 (4omhs W/ DVC) and am paring up with a alpine MRX M110. Just wondering if this is going to over power the sub to much or if i should not worry.
The sub is good for 1200 max and 600 rms
The amp puts out 1100 watts rms at 2omhs and 650 rms at 4 omhs.
From what i know you cant wire a 4 omh sub to 4 omh load. If you do parralle wiring it will make it a 2omh load correct?
If that is correct is 1100 watts rms going to be to much for the sub or if i set my gain low will it be alright?
Also i was just wondering what i should set my lpf to? I was thinking about 80 to start?
Thanks
ull be fine just set gain correct and ull have no prob i have a kicker zx1000.1 on 1 sundown sa-8 just have my gain down real low
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
227
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
430
Mack199
Mack199
Alberta
urmomsmin3
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
