Elemental Designs Nine.5
06goat
bumpin bluegrass
1,873
Michigan
Elemental Designs nine.5
In good working order, havent had it powered up in 3 years, its been collecting dust and Ive finally decided to let go of it. Couple dings but what do you expect for a used amp?
These things are ripper amps, if you need the specs youre probably not worthy.
Starting with $375 shipped. I really have no clue what theyre worth so please dont hesitate to make an offer.
Disregard the 2x4s its screwed to.
Ive got one..Pretty clean with a bass knob.One hell of an amp.All the specs you search and that are brought up are for 12v.Itll run and entire system for sure.Deff keep up with 4- 1500 rms subs all day long on front stage if you have a front stage worthy enough.GLWS
It beat the hell out of an XFL 12 @1 ohm at 14.6 down to 12.6 in 2.4@32 htz without a sweat,along with a pair of CDT Briaxal 6.5 components and a set of Kicker KS25 tweets and a set of CDT HD 6.5s
List the specs anyway....some people wouldn't mind seeing what this o/s ****** amp can do. Don't be an ******* about it.
Continuous Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
Continuous Power @ 12.5v : Subwoofer Channel
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
For the right offer Ill move it! Gotta be pushing at least 800rms on this thing at 1 ohm at 14.4... my xxx sounded wayy too good on this thing. Could work out a package deal on the two if theyre bought by the same person!
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
06goat
bumpin bluegrass
06goat
Michigan
NeoGeo401
    May 10, 2024
3toneEYZ
    May 10, 2024
