Elemental Designs Nine.5
06goat
bumpin bluegrass
1,873
Michigan
Elemental Designs nine.5
In good working order, havent had it powered up in 3 years, its been collecting dust and Ive finally decided to let go of it. Couple dings but what do you expect for a used amp?
These things are ripper amps, if you need the specs youre probably not worthy.
Starting with $375 shipped. I really have no clue what theyre worth so please dont hesitate to make an offer.
Disregard the 2x4s its screwed to.
Ive got one..Pretty clean with a bass knob.One hell of an amp.All the specs you search and that are brought up are for 12v.Itll run and entire system for sure.Deff keep up with 4- 1500 rms subs all day long on front stage if you have a front stage worthy enough.GLWS
It beat the hell out of an XFL 12 @1 ohm at 14.6 down to 12.6 in 2.4@32 htz without a sweat,along with a pair of CDT Briaxal 6.5 components and a set of Kicker KS25 tweets and a set of CDT HD 6.5s
List the specs anyway....some people wouldn't mind seeing what this o/s ****** amp can do. Don't be an ******* about it.
Continuous Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
Continuous Power @ 12.5v : Subwoofer Channel
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
For the right offer Ill move it! Gotta be pushing at least 800rms on this thing at 1 ohm at 14.4... my xxx sounded wayy too good on this thing. Could work out a package deal on the two if theyre bought by the same person!
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
3K
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
3K
06goat
bumpin bluegrass
06goat
Michigan
NeoGeo401
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
