Enclosure for an inverted mounted sub, does the mounting size change?
  • 3
bassranddy
I'm not sure if my subs excursion will be limited or worse, if my subs surround will take damage if I mount my sub inverted. I don't know if for my 12 I leave the opening at 11 inches or if I flare it or what.. any input would be greatly appreciated!
I always go a little bigger (little meaning ~1/8") and roundover with a 1/4" bit and align and mark the sub mount holes to ensure center placement before the sub is mounted. Hope that helps.
Sent from my SM-N920V using Tapatalk
Woah Chris...your still here!!
OP, some people open up the mounting hole a little more for surround clearence. And since a lot of subs have bigger surrounds on todays subs, it's a good idea to do so to prevent damage.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
4K
bassranddy
bassranddy
Miami, FL
Boomin_tahoe
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
