If 8" woofer needs .75+ cuft for optimum, should I only include one in my box?
  • 5
Jonnyiphone
I have a 2013 F150 Crew Cab and I want to build a box under the back seat. I can see from others that have posted their boxes online that there is about .65 cuft per speaker in a box back there. Since my 8" says it needs .75 to 1.25 cuft for optimal sound then would it be better to only include one woofer in my box?
I once took 10"s out of a box and cut holes bigger for 12"s and I lost a lot of bass...
No, I am about to build a box but I need to decide what will give me the best performance in a box with roughly 1.3 cuft. Should I buy two woofers or is that overkill for the space I have and wouldnt just one 8" sound better with the limited space?
Well yeah...bigger subs that usually require more airspace.
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
3K
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
865
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
4
Well yes, I've searched cruthfield many times, I just wanted input from actual people to go off of instead of numbers and prices. I've got it...
6
Jonnyiphone
Jonnyiphone
Houston
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
